Cold vs Hot Oil Indication
2.9K views 6 replies 4 participants last post by  flyrider
#1 ·
Just curious...what difference do you note between your bike's cold temp oil indication vs the indication after it's hot...
#2 ·
Maybe you should have asked this in your other Oil Level thread?
http://www.s1000rrforum.com/forum/maintenance/48834-oil-window-indication.html
I find the difference to be about an 1/4 inch (6mm) between absolute cold and piping hot, and I fill mine to near the top of the sight glass when it is absolutely hot. That is why they tell you to check it when it's hot - not warm, and not cold, but HOT. The level does change with temperature and you don't want to overfill it.
I'm also going to state a disclaimer. I wouldn't guarantee you the volume is linear from the bottom to the top of the sight glass either. Just be careful and add to it a little at a time once you come within the last quart or liter.
#5 ·
Well, I asked this question because mine was sitting around 1/2 level in the window, cold. I added enough oil to bring it to about 3/4 level, cold. My experience has been that 3/4 cold will result in about full, hot.
But then I got concerned, because the temps have been in the 20' and 30's, and I haven't ridden for a few weeks. Made me think that adding a little (and it WAS a very little amount...about 2 fluid ounces or so...maybe 1/10 quart) was a dumb way to counteract the boredom of not being able to ride. Worried that it'll be overfull when I get to ride it to operating temp.
That's why the 1/4 inch observation from Rainman was important to me...now I think there'll be no problem.
Just goes to show how not-riding can breed some weird behavior...:rolleyes:
The oil in the bike is fresh...oil change 200 miles ago...
